MALLERY/ACCEL question
#1003360
05/31/11 12:31 AM
05/31/11 12:31 AM
Posts: 5,618 long island NY
Ari440
long island NY
hello Im working on a 69 barracuda 440 4 speed dos any one know how to wire this ignition up some pics thanks
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question
[Re: Ari440]
#1003362
05/31/11 03:31 AM
05/31/11 03:31 AM
Posts: 43,215 Bend,OR USA
Cab_Burge
My on Mallory Unilites is don't use them , They (the light)will fail without warning I ahev seen it happen way to many tiimes for it to be a odd occurance, way to many times.You would be better off with a stock point distributor Any progress on getting that intake and carb. set up running yet?
[Re: Cab_Burge]
#1003363
05/31/11 06:42 AM
05/31/11 06:42 AM
Ari440
long island NY
thank you BOBBY
CAB this car has been sitting for 15 years ,the guy asked me to put it together , moter trannie where in the car , he couldnt finish it off
this is what I have to work with for now
the sixpack is working fine ,got a car show troffy (sp) for it
car is faster then a 1050 carb on it
1.39 9.85 - 137 mph
[Re: Ari440]
#1003364
06/05/11 09:39 PM
06/05/11 09:39 PM
Ari440
long island NY
hi Im having a problem with the igntion system have very low voltage at the coil and very weak spark / will not start this was a 340 car ,is the blue wire for the coil check the ballast rissiter (sp) power going througth it any other ideas where to check EDIT / ALSO whould the ignition swicth give you low voltage
1.39 9.85 - 137 mph
