T/A Exhaust Manifold gaskets?
#1002175
05/29/11 04:42 PM
05/29/11 04:42 PM
Posts: 907 Mississauga, Canada
KARLN
Mississauga, Canada
Do I need to use exhaust manifold gaskets when re-installing my manifolds? I know there's a metal guard on the driver's side but are standard gaskets also required?
thanks,
B5 Challenger T/A
Re: T/A Exhaust Manifold gaskets?
[Re: Alaskan_TA]
#1002177
05/29/11 07:39 PM
05/29/11 07:39 PM
KARLN
Mississauga, Canada
thanks Barry. Will there be any issues with leaks? I noticed that gaskets are available for exhuast manifolds from 68-70.
B5 Challenger T/A
[Re: LemonTwiist]
#1002180
05/30/11 10:32 AM
05/30/11 10:32 AM
KARLN
Mississauga, Canada
great info guys. Just to clarify, I'll use the factory metal sheild as the gasket on the driver's side and the trimmed material gasket on the passenger's side?
B5 Challenger T/A
[Re: 440maxwedge]
#1002182
05/30/11 05:28 PM
05/30/11 05:28 PM
KARLN
Mississauga, Canada
thanks again for the update. I'm restoring to OE level but also don't want any leak issues. I've got the heat riser installed for appearance but welded the butterfly in the fully open position. Hopefully that should solve any leak or seizing issues.
B5 Challenger T/A
[Re: LemonTwiist]
#1002185
06/01/11 09:45 AM
06/01/11 09:45 AM
KARLN
Mississauga, Canada
Hi Lemon Twist, great job on the detailing. Did you use both a fiber gasket and the metal sheild on the driver's side?
B5 Challenger T/A
[Re: LemonTwiist]
#1002188
06/02/11 11:44 AM
06/02/11 11:44 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
This is a timely post. I'll be installing my exhaust manifolds on the my 340 pretty soon and never realized that they did not come with standard gaskets. I knew about the metal heat shield but did not realize that gaskets were not used. Interesting.
Joe
65 Barracuda 70 Challenger
