T/A Exhaust Manifold gaskets? #1002175
05/29/11 04:42 PM
05/29/11 04:42 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
Do I need to use exhaust manifold gaskets when re-installing my manifolds?
I know there's a metal guard on the driver's side but are standard gaskets also required?
thanks,
B5 Challenger T/A
Re: T/A Exhaust Manifold gaskets? [Re: KARLN] #1002176
05/29/11 05:10 PM
05/29/11 05:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No gaskets where they meet the heads, just the heat sheild on the driver's side.
Re: T/A Exhaust Manifold gaskets? [Re: Alaskan_TA] #1002177
05/29/11 07:39 PM
05/29/11 07:39 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
thanks Barry. Will there be any issues with leaks?
I noticed that gaskets are available for exhuast manifolds from 68-70.
B5 Challenger T/A
Re: T/A Exhaust Manifold gaskets? [Re: Alaskan_TA] #1002178
05/29/11 10:31 PM
05/29/11 10:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Factory heat shield on the drivers side IS a gasket
but no gasket of any kind from the factory on the pass side
Re: T/A Exhaust Manifold gaskets? [Re: KARLN] #1002179
05/30/11 07:31 AM
05/30/11 07:31 AM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Unless your heads have been shaved and your manifolds shaved you WILL have a exhaust leak. I always use a gasket, but trim them to the outline of the exhaust manifold ports. Once installed you won't see them and you won't have any leaks either
Re: T/A Exhaust Manifold gaskets? [Re: LemonTwiist] #1002180
05/30/11 10:32 AM
05/30/11 10:32 AM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
great info guys.
Just to clarify, I'll use the factory metal sheild as the gasket on the driver's side and the trimmed material gasket on the passenger's side?
B5 Challenger T/A
Re: T/A Exhaust Manifold gaskets? [Re: KARLN] #1002181
05/30/11 01:53 PM
05/30/11 01:53 PM
Texas
440maxwedge Offline
440maxwedge  Offline
Texas
I just did this. I agree with the above post, unless you have resurfaced the manifolds and head mating surface, without a gasket you will have a leak. I put a gasket between the right manifold to head, and a gasket between the manifold and the heat shield on the left side. I know this is a 340, but for the record, 440/383's are the worst. The correct way is to resurface both, but that requires much more work. If it's restored oe, no gasket.If you are chasing a leak, better check the heat riser--known issue.
Re: T/A Exhaust Manifold gaskets? [Re: 440maxwedge] #1002182
05/30/11 05:28 PM
05/30/11 05:28 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
thanks again for the update.
I'm restoring to OE level but also don't want any leak issues.
I've got the heat riser installed for appearance but welded the butterfly in the fully open position. Hopefully that should solve any leak or seizing issues.
B5 Challenger T/A
Re: T/A Exhaust Manifold gaskets? [Re: KARLN] #1002183
05/30/11 05:47 PM
05/30/11 05:47 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Re: T/A Exhaust Manifold gaskets? [Re: badblack68] #1002184
05/31/11 08:56 PM
05/31/11 08:56 PM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Here is what it should look like when done correctly
Re: T/A Exhaust Manifold gaskets? [Re: LemonTwiist] #1002185
06/01/11 09:45 AM
06/01/11 09:45 AM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
Hi Lemon Twist,
great job on the detailing.
Did you use both a fiber gasket and the metal sheild on the driver's side?
B5 Challenger T/A
Re: T/A Exhaust Manifold gaskets? [Re: KARLN] #1002186
06/01/11 10:17 AM
06/01/11 10:17 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Karl,
when I did my old challenger 340 .
The current 340 heat shield was not avail.a the time.
So, I used a heavily modified 318 shield,
Combined with standard exhaust gaskets. The ones I used had fiber on one side with metal on the other.
To get it as thin as possibile to hide them, I just removed all the fiber material on the one side and used the thin metal side. Never had a problem.
trimmed gaskets were on both sides to prevent leaks. I never had a problem.
Re: T/A Exhaust Manifold gaskets? [Re: KARLN] #1002187
06/01/11 09:52 PM
06/01/11 09:52 PM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
I didn't take a chance on the drivers side so I used a gasket on that side too
Re: T/A Exhaust Manifold gaskets? [Re: LemonTwiist] #1002188
06/02/11 11:44 AM
06/02/11 11:44 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
This is a timely post. I'll be installing my exhaust manifolds on the my 340 pretty soon and never realized that they did not come with standard gaskets. I knew about the metal heat shield but did not realize that gaskets were not used. Interesting.
Joe
65 Barracuda
70 Challenger
