here is the template I made for the additional RH inside quarter tank. We're drawing it up in CAD, will make the aluminium shell to test fitment, put mounting tabs etc in place, including making fittings to connect to main tank, & std filler cap's on both 1/4's. We will then send the spec to ATL to make the internal bladders that will fit inside.
