Quote: As an update, I looked at my lower alternator bracket and I don't think that it is correct. It does not have enough adjustment to get the belt as tight as it should be.
Yeah I ran into that & if all the bracketry is good I got a SLIGHTLY shorter belt (it dont take much). Take it in w you
