Soooo, what's that mean?
Are you poo-pooing the idea of spending around $20 or less to tune a carb before throwing down several hundred $$ for a Holley?
Others, see attached for the set of metering rod springs mentioned.......
http://www.edelbrock.com/automotive_new/mc/carbs_acc/access_calibrate.shtml
Your Joking , Correct ???
First Thing , I Never Mentioned Holley
Second Thing , I Could Tune A Edelbrock , Carter AVS All Day / Any Day - I Love The AVS Series Actually , Original And New - I Take The Original Factory Carter Avs,s and pull off the metering rod covers and make my own flat metering rod covers and tune them with the Edelbrock Metering Rods / Springs And Jets (Finding the Carter AVS Strip Kits , Three step metering rods and tall primary jets is next to impossible)
ANYWAYS with that said
The 1407 / 1411 Performer Series Is Nothing More Then A Overpriced Parts Carb - Actually Thats Beeing To Nice , How many beer cans could we make out of a 1407 Carb ??? That would Bee more productive and definetly a wiser choice
Bottom Line - You cant tune a internal design flaw with springs
That series , 1407 / 1411 is the most and WORSE talked about carb on Moparts.com - Probably the world wide web for that matter
For every 1 positive there is like 100 negative posts about those /1407 1411 series
Carry On
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
