Now should I just clean the aluminum waterpump,,,,,or should I stick it in the beadblaster cabinet to spruce it up.I need to do the alternator too
You dont want beads inside the housing as they'll lodge in crevices & cant b blown out w air & then release when it gets hot & lodge in rad tubes. Cover the housing openings ten ways from sunday & bolt on the pump & cover the pump seal area under the cross. If the alt halves are totally stripped w no place for beads to hide it'd work good. Glassbeading has it's place but on the outside not inside
