You aren't going to find pulleys in increments from a company , you have a few pulley choices , B/RB , 69 up hemi , B/RB A/C and small block. The B/RB sits real close to the pump. i assume spacing the bottom pulley out is not an option ?
Post up a picture of the pulley it self , do you know the pulley application.
You jarred my old memory,went through a few part bins and look what I found ,,,but it seems to be a larger diameter pulley and might be touching the crank pulley.The back of THIS pulley almost touches the 4 waterpump to housing bolts.
HEMI-ITIS has no cure. My condition is fully BLOWN!!
