Have you thought about machining the engine side of the water pump? I know guys that have run mounting plates on the front of their engines and corrected alignment by machining the water pump.
Yes Ashley.There is .150 to .175 to be found with a quick shave.I will wait untill I obtain a shorter blower snout and ATI crank damper before the milling if need be.Thanks for that suggestion
Now should I just clean the aluminum waterpump,,,,,or should I stick it in the beadblaster cabinet to spruce it up.I need to do the alternator too
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
