The first thing they do on a dyno is run the engine for about 15 minutes with a slight load on it at about 2500. this gets everything up to temp, fluid leaks checked, timing set, cam break in if flat tappet.
After that its an all out assault. After that, the rings are broken in (or not if there was a problem)
