Re: 302 heads
[Re: asesino]
#949518
03/14/11 05:47 PM
03/14/11 05:47 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Hi, I wonder how good are the heads 302 (4323302) and I put some on my 318 and I have heard positive and negative comments, I would like to know the fifferences between 302 and 308 (which are better) as they relate to burn fast as i was researching and a page read that thanks
what kind of camshaft have a 69 340 ,because i want put one or similar in a 360 w magnum heads and hypereutectic pistons,,, how so good it is??
Asesino - What are you building, a 318 or a 360? Do you want fuel economy or HP? Magnum heads or LA heads? (there are a bunch of parts you need to change for that conversion)
Until you specify, the answers you get may not be suitable for your goal. (a 'just build a 408' response is destined to happen soon )
