Just build a 408
Seriously though a 302 head can be made to flow at least 220 and 163 with 1.88 1.60 valves. I have a set that has been CNC ported and that is what they flow at .500.
wow, that's 18CFM better than RyanJ got on the exhaust port of a maxed out 302 IIRC.
so for all that porting, they flow about the same as stock mags, or less than the LA intake pattern enginequest 318B's you can buy new from hughes engines assembled for $725/pr
Hughes Iron Ram heads
as cheap as these are, I can't see spending the money on building used LA heads if they need new valves.
1976 Spinnaker White Plymouth Duster, /6 A833OD
1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!***
2011 Toxic Orange Dodge Charger R/T
2017 Grand Cherokee Overland
2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
