302 heads are a good, cheap way to get a little more hp and they are closed chambered which is a good way to bump compression. The 308 head is the same head but had bigger valves. these were used on the 360's. these heads are good performers with mild porting.
#08 heads are most definately NOT the same as 302's with larger valves, not even close. 308's are 360 type heads with all that entails, not 318 heads with bigger valves.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
