DRE made mine ...
The straps are a real pain, especially the rear two. The front straps attach to brackets on the front header bolts, the rear are positioned between 5&7 and 6&8 so going to either header bolt interferes with the plugs. I drilled and tapped the header flange between the two cylinders for a stud that the bracket mounts to.
That stud is a good idea.... for headers with a full flange, mine are cut separate with nothing between them. Something can be fabricated, but it takes money.
