http://www.russlerii.com/ ....and besides if you have any issues he's just a drive across the mohave for you. Been a few members here that have had blankets made by him.
Sounds good, and $158 is priced OK.
But it looks like those hugh metal ends will have problems fitting on a header flange? On mine (2-1/8), you have to used reduced head bolts (3/8 thread, 5/16 hex) and you can't fit a washer on there never-the-less that metal strap end???
Does anyone have a close up picture of how that goes on the header bolt/flange?
And how about a sewn cut-out for the engine mount to frame connection? I use a front motor plate, but the passenger side engine mount is used as a fore-aft travel limiter/brace.
