Re: Obtaining quench in a slant 6?
[Re: polkat]
#931537
03/01/11 10:22 AM
03/01/11 10:22 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Yea, it would be too deep. The recessed area in the head is nearly .200" at the edges, and taking that much off the head would make the head deck a bit too thin.
I have heard about a piston, the KB268, that might work for this with the 198 rods. Will check it out.
I figured it might be too deep. The big block head looks doable, and some here have done it. But .200" would pooch that head i'm sure, unless the decks are 1/2" thick. Heh heh... its a slant 6, you never know, gotta be SOME good reason why a tiny 6 cyl engine can weigh 475lbs...
And last i checked (3 or more years ago?) there was no non-Mopar head that could be physically bolted onto/mated to a slant six. Apparently the slant guys have tried EVERYTHING... and i do not doubt them. But... it has been at least 3 years... and there have been a few I-6's introduced into the automotive world. If i was a slant six guy, that would be my quest... finding a modern head to bolt onto that block. Beyond the obvious benefits, making quench would be easy. But i suppose we're transcending the original question now...
