The cam looks pink to me. What would you recommend?
I also got a secondary metering plate conversion. I'm thinking of starting with 82s. I've got a part throttle knock at around 75mph that some others have thought might be a lean condition as the secondaries start to come in. I'm actually thinking of starting with converting the secondary over before I start messing with the pump shot.
