Quote: I had a similar problem. In neutral the engine would take a quick snap of the throttle. In low gear, again no problem. In a higher gear a quick snap and it would cough.
Do not accept it will not work with a tall gear. My truck is a manual trans and even in 5th, I overcame the bog.
