Al, you must be one of the original buyers of that kit. I started to make the Wilwood adapter back in 1999 so it has been just a little over 10 years.
I recently designed a kit that uses the radial mount Wilwood calipers. These calipers have weather seals on the pistons. The radial mounting is also more rigid than the ear mounts. But the radial mount calipers are a lot more expensive than the older ear mounts so this new kit hasn't been that popular.
Where does one get the rotors for this? I have a WW kit with a solid rotor that I may steal the Dynalite calipers from and put them on the GTX. It has factory KH discs but I wouldn't mind saving a few pounds.
The factory 11.75 inch rotors were used on 76-78 B-body and 79-up R bodies. Raybestos part # 7038R, NAPA part#NB 4885579. I believe Wagner and Bendix also have them but not sure on those part numbers.
