Just do it. I ran a 323 geared 440 B body all over the joint with a 10" turbo action, factory radiator cooler only, never burnt trans up. It won't be slipping too bad to pull your B body around under minimal load. I could not say the same thing if you were hauling a 5000 lb or more trailer, up a steep grade for many miles though.
