If there is no obvious wear at the fulcrum of the rocker to shaft area they're good.
EVERY old Mopar big block I've torn down had some play, in the fulcrum, that was taken out when the oil pressure went up. Not an area of HIGH tolerances held when manufactured as far as I'm concerned. Or maybe it didn't matter when they knew the lifters would compensate.
If you have a replacement PERFORMANCE cam it may have a "smaller base circle" of which is known to cause more valvetrain noise. The fix is longer pushrods or adj. valvetrain.
on the longer pushrods or adjustable rocker setup with the "smaller base" cams. But wouldn't a simpler deal in conjunction with longer pushrods be, the "six-pack" rocker arms, shafts and hardware? Especially, if you have a complete LOW or NO mileage set just laying around collecting dust! After all, they are the "service replacement" for the standard stamped-steel rocker factory rocker arms.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
