Bobby,
My setup is a 70 340 block bored .020 for 4.06 and a cast 4" crank = 414 cubes. Been that way for about 8 years now!!!! 11.2 to one compression, ported E heads, 260 @.050 solid cam. Running low 11's at 121mph on pump 93 octane with full timing at 34 degrees.
Probably around 525 to 550 hp at the crank, using different calculators.
Have fun!
