I did this swap last year in my 67 Barracuda.. 94-95 models are the easiest to swap sinc you only need to connect the engine to the computer, it's a stand alone system.
Running a 904, you don't need the vehicule speed sensor as the governor will do the job..or anything hooked to the trans... 4 wires to connect and you're ready to go !
The only hassle is tp mount the electric pump in the tank....use the stock unit.
Dan
thanks,,can you run a earlier computer on a later engine??
i have talked,,E MAILED,, read every thing i can find,,it seems like no one wants you to do this swap,, ive contacted places that have rebuilt computers, 2 or 3 places,,they want a vin# to program any computer,, with this 97 motor ive been told ill need a stich shift computer,,
did you re work your wiring or send it out ?
mega squirt stand alone KIT complete 950.00 then u need a lap top,,geez they sure dont make it easy i applowd you on your conversion
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
