I see the hump needed a little trim with the ramrod shifter...would a reg stock hurst shifter fit the hole?? wondering just for referance...
A regular hurst 4-spd would have fit perfect - the ramrod boot will cover all the cut-out section perfect
did the holes in the floor need trimed or are they big enuff they way we cut them??
Didn't have to touch what we originally cut....we're good.....!!!!!!
nice tuff wheel also
Thanks, wasn't sure if I'd like it or not, but now that it's installed I do.
did you cut your stock hood or is that the light hood you talked about???
It's the stock hood, didn't want to drive for 3 hours to ck out the US BODY hood....these aren't that rare and I did keep the cut out just in case....lol
I guess i could trade you the V-stack back for another aircleaner set up for the 440
maybe a nice K&N with the extrem top
{{{{ NICE TRY }}}}
next time I am down I will bring some rods and see if you will let me use the welder under your bench to weld the spring pads on my truck...which are not done yet
