Ok on my 73 Charger driver's side front caliper. I initially replaced everything during my restore. Caliper, hose, washers, bolt, and brake lines. This line keeps leaking at the banjo bolt. It's hard to determine if it's leaking between the brass hose block and the caliper or the block and the bolt because it's too wet. I replaced the washers 4 different times and even tried the original Chrysler thick washers. I rechanged the banjo bolt. I even warrantied another caliper. I finally tried a new brake hose last night. It's still leaking just as bad. And this only just sitting in the garage. I haven't even driven it yet. The other side caliper is fine. Should there only be one washer on the banjo bolt? In the 73 parts catalog it states 4 required. But I don't know what else to try now.
