Thanks Bob, and your definitly correct. The main thing is to go and have fun which I have from the very first Curt George Memorial!
Eric; Minimum dial for the open body is 5.3. I can usually manage a 5.1 in PRP bad air. Fully Bodies can run a 5.70. If you sign up for Quick and do not make the field you get an automatic entry into Super Pro.
Bob spelic
Bob Spelic
