If I found a 87 era Dakotawith the V6 in it, will the k member take the V8 or will that have to be replaced.???
Rumblon
I would like to think its the same K frame,but i do not know for sure,,but the 1987 3.6 v6 is a 318 minus 2 cylinders,i would think they share the same block motor mount ears,,,either way its not hard to fab a bracket to use the spoool mounts,,also you can check a guy callled schumaker he makes all sorta of adapter and better then original mopar motor mounts
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
