Yep, I'll call Hughes in the morning so that I can be truly informed.
I will agree with you on this, Hughes is not all they are "cracked" up to be..
Interesting to note Mancini racing sell three different brands of cranks including cast eagles.
Things that make you go hummm? If eagle cast cranks were such an issue why would one of the top Mopar houses carry this product?
When you call the Hemi hot line they have no ill feelings about anyone using cast eagle cranks and have no mass reports of eagle crank failures?
To me this whole post was likely started by a few ill informed Scat fans.
According to my local speed shop it is Scat that is having the quality control issues, not Eagle.
