If and when I go with the Megasquirt to do fuel management, I will use the Mopar injector connectors but use my own wiring to keep it a little less confusing.
Find the '5.9 EFI a different way' thread, I put some info in there about a nearly-standalone injector harness that can be pulled from a Northstar. Easiest & cheapest route to wire injectors, IMHO.
ok thanks ill search for it,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
