If and when I go with the Megasquirt to do fuel management, I will use the Mopar injector connectors but use my own wiring to keep it a little less confusing.
Find the '5.9 EFI a different way' thread, I put some info in there about a nearly-standalone injector harness that can be pulled from a Northstar. Easiest & cheapest route to wire injectors, IMHO.
