While I don't disagree with Indy's service after the sale I do disagree that there products are junk. I have ran the same pushrods and rocker arms for ten years with no problems. Last year I broke a rocker arm. Replaced with new set of Indy's. Still using same pushrods. Care must be taken to ensure proper pushrod length so not to much adjuster is protruding from the bottom of the rocker. I think ten years on the rockers is pretty good. I cut and press my own. Never galled one. Did gall MP pushrods years back. Just my opinion.
but what kind of spring pressure are you running thats the biggest deal with the Indy rockers and push rods
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
