well, this is slightly [sorta] off topic, but i "disguized" my cousin charlie's motor for his 29A roadster pickup. the idea of using up a pair of mashed valve covers is a good idea. i wanted to go with a set of "internationals" , but charlie didn't like that. so i did this....
look real close at the one on the right.....these fit up really good, with the mounting studs the only work involved. and the welding of the pvc & the breather holes too.....i will add those in an inconspicuous place on the intake.
