Quote: I'am not being a smart a$$ but I call BS.When you bush them all your doing is making them all the same size.The angle is not going to change.
Im not either a smart a$$, but if the bushing you are pressing in is thick enough you can accually manipulate the angle slightly, and then finish true the bores after the accual desired angle is achieved couldnt you?
You could do it that way but any follow up work work such as replacing a damaged bushing in the future is pure guess work. By correcting the bore location and geometry up front, you can pull out the bad bushing, pop in new ones, hone and go.
