I once did a master cylinder replacement on a VW Rabbit and could not get pedal after bleeding the brakes many times. Finally discovered pin holes in the hard brake lines leading from front to rear in the perimeter of the driver's footwell!! Car had a water leak in the cowl and soaked the carpet backing, kept the tubing wet and over the years pinholes developed! Trace the metal lines and verify no leaks is my suggestion.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
