It can only really be two things...Master cyl or air...When you bench bled the master cyl did notice if fluid leaked out immediately after you pored in the fluid? (rule of thumb..if the fluid comes by the residual pressure valve immediately after pore put it back in the box) You've covered all the bases go back to the master...My guess is the check valve is not holding ...
