Thanks guys!!! The the quarters really aren't bad except they were damaged and now oil can badly. I've been advised by a good body guy that putting skins on would be/look the best. I cut the driver's side off about 12" down from the top so I don't have to go all the way up to the top. The passenger side was damaged behind the door, drilled and pulled. I have NOT cut it and may not if I can figure a way to get the oil canning out of it. That side really only needs lowers in front/behind the wheel. There is no rust in the wheel opening. So, with this info what say you now?? I know, let's see the pics. Unfortunately I can't get/don't have pics. Thanks again!
