The car is looking great. It's very cool that you are restoring it. Have you attempted to contact Jack Roush regarding it?
Quote: Hi Guys, Thought I'd post a couple of quick update photos of the car. Got quite a bit done to it the past month. Installed new stainless fuel lines/AN fittings under the car, new battery cables front to rear. Adjusted the coil overs down a bit over an inch to help the stance until I get the rear suspension restored back to original
Also installed new 5 lug rotors, calipers, hoses, master cylinder. It had no brakes when I got it. Had the wheels restored back to their original machined finish, nice original center caps, correct lug nuts, new tires. Used 30-13.5-15 M/T ET streets on the rear and Firestone Wide Oval D70-14's on the front.
I think the wheel/tire combo turned out great. At least it doesn't look as homely as it did
Next project is turbo removal and header fabrication. Once done, I can install the correct hood/scoop as original.
