Mike did a strap bolt come loose or a needle bearing get moved out of place around the perimeter if a cap was taken off & put back on. When R&R ing a ujoint both ears on that end of the shaft need to be whacked between the shaft & the half moon ujoint cap with a medium blow w a bfh to align the ears back after the ujoint caps are pressed in so. Test by moving the cross (rear)back & forth in it's plane & the front yoke (front) in both its planes & it should be free & no roughness/binding. How did our joint venture on the carb turn out?. Found out you cant send metering rods in the mail because their machines have a problem w metal even a minute amt in an envelope. We were lucky one rod showed up! they must have figured it wasn't a terrorist device & resealed the envelope & sent it on it's way.
haha, remember Robert, we think terrorist attack all the time here in the Washington DC area...lately it's been from Congress and the White House on we, the American taxpayers.
I gave up on the AVS and borrowed a Edelbrock performer 600cfm from someone locally. Thats was I was testing when this occured.
