Quote: Typically something breaks, to cause a shaft to come out.
BUT.... Something like what's in the pic, could be caused by forgetting to put the snap rings on the caps. Without a snap ring, the cap just flys outward under the straps.
I had the u joint pressed in the shaft by a local shop so a)I don't know if any snap rings were there at all to begin with and b) I didn't look for any as I didn't know there ws supposed to be any there in the first place and c) I just put it up on the yoke and torqued the two straps up. uh oh
