Quote: Chiming in... a stopped up idle bleed will definately make the idle circuit rich. If the bleed is 100% stopped up it probably siphon the entire bowl empty after you shut it off. The same will happen with the main bleed except you will see the discharge port dripping after shut off untill the bowl is empty. Got to go to a Movie now Curt
