Tell you what Dave I'll finish my 302's and get the valves done and mildly shaved. This is after the Duster leaves the driveway with the 4 speed.
I'll give you back your Stromberg that you lent me. Then you can try it.
We can see how my heads with the RUG _ TRUCKER MPG, low to mid torque work. CC them then test them. Then cut them with grooves retest them and see if that treatment will change things.
IIRC I need to finish 2 exhaust ports.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
