The trans will bolt up but the torque convertor will have weights designed to balance the cast crank 400... If you were planning to replace the torque convertor then no biggie.... The earlier trannies tend to have heavier duty clutch packs... Though a truck unit likely has good stuff in it... I've taken apart a few 75-77 vintage big block trannies with only 3 plates in the front clutch.. earlier stuff even smallblock always had 4 plates...
My engine has 450 horse and I will be putting a load on the tranny via burouts, racing, etc. Would the truck tranny not hold like an older tranny would?
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
