Nope It had fuel in it, I even put more in it.. I am running a fram filter. I was thinks that might be it. But any how its got two -8 off the tank to a Y then to the fram fiter, to the pump with -8 and to the front of the car with -8 to the regulator, and two -8s to the carb..
IMO Fram fuel filters are junk. Further more they are not intended to be suction side filters. I am not at all surprised you are having problems. Your pump is cavitating and will soon be ruined if it isn't already. You need to get a suction side filter to keep crap out of your pump and a pressure side filter for the finer stuff that gets into your carb. RobbMc from this board has everything you need.
