First thing I thought of while reading your post was ,did he forget to put the fuel in? Maybe you have a pinched line? crap in the filter. The new pump seems to be building pressure while the motor isn't using it but can't keep up at high rpm.I would put the old blue back on to see if it is the new pump.
it's ok to butt heads, just don't do it with a butthead
