Re: Bad night at the track
[Re: Cab_Burge]
#438349
08/15/09 12:31 AM
08/15/09 12:31 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
What do ya mean MR P Body.. How do I check that??
You disconnect the fuel lines to the carb and place them into a safe container, two or more gallons, bigger is better on this one. Turn the fuel pump on fornine, ten or eleven seconds and measure the amount of gas in the container in ounces, do the test several times (sameamount of time on each test )so you get a average. Barry Grant has a chart for fuel consumption measured in how many seconds it takes to pump one gallon, hopefully some one who knows how will post a link to it what I remember is a nine second car needs to pump one gallon in twenty seconds or less, a ten second car needs to do it in 25 seconds, I think anyways. I might have the numbers skewed some IHTHs
Thanks Guys, I'm just pulling my hair out with this one. It was such a wasted night.
