Your compression does not sound bad, your motor is very low compression ratio and will not pump up big numbers unless you put something with VERY short .050 duratio in it. I had a stock cam from a 273 2bbl in my 318 with 10.0 compression and it pulled 20 inches vaccume so your vaccume is not the end of the world.
I think your carb or ignition is the problem
