I've got a 2000 with an AUTO , 212k miles , 120k on the trans since a rebuild and the wound on the trans was self inflicted , the VP FINALLY died ata 212k , the low sulphur fuel and a lift pump putting out only 5psi were it's DEMISE , 416HP at the rear wheels , ran it out of fuel more times than I care to admit , drove it for weeks with an inop lift pump ...
don't believe everything you read on the internet .
