Quote: It still does not mater if its a 500 tree or a 400 tree you just roll more in the box was taking to my brother in law about boxes this morning.Also you have to give Lonnie credit he is racing by the RULES and doing a good job at it
But......a 3350 lb car can't react quick enough to use a box.
Then you need to put your 3350 lb car on a diet. Rule are rules, just do your best with what you have.....Phill
First of all, my car weighs nowhere near 3350 lbs. I'm just stating, that a high-9 or 10.00 car can't react at 3350# like a mid-9 car at 2200#. I don't care if Darrell Alderman is running the car.
A .500 tree would even up the starting line advantage.
The CRT 10.00 Shootout is a fun race that a lot of people like to run. These races are usually tight! Not many want to ante up an entry fee knowing they have a .12 disadvantage on the tree.
I'm not bitching. I just understand the point being made.
