The two cams Comp showed that would give me the best torque and hp numbers were the XE262 and XE268H. The XE262 would give me 380hp and 440lb. while the XE268H would give me 390hp and 430lb. So which would you guys go with? Torque or HP?
I have ran the Comp Cams 268 grind in a 400ci big block and it was great for a street car. Pulled good, idled decent and I thought it was a good all around cam.
CrAzYMoPaRGuY
