If you can afford the h beams do it, I would save some where else on the build and use good rods, you can shop around some and do better than 500, Even though stroker rmps are lower the piston speed is way up there and puts more strain on the rods, there are the bushed I beam rods also , the big end on I beams require less grinding on the bottom of the cyls and are stronger than stock
